'90 300zx alarm install
lrciii
Member - Posts: 15
Posted: June 13, 2002 at 10:21 AM / IP Logged
I'm going to be installing a alarm system in my 300zx, adding remote door locks, raise the windows on arm & power rear hatch release. I'd like to keep the factory system intact as well, let it handle the starter disable etc. Is there an EZ way to disable the factory alarm when I hit the door unlock or hatch release button on the remote? Same idea, when the hatch is closed, automaticaly re-arm?
Thanks!
Lee
Big Dog
Gold - Posts: 1,265
Posted: June 13, 2002 at 12:06 PM / IP Logged
Hey lrciii ,
In order to arm the factory alarm you have to send a negative pulse on the blue/red wire in the driver's kick or Anti-theft module which is located under carpet on passenger floor board.  To disarm send a negative pulse on the gray/red wire in the driver's kick or Anti-theft module.   '90 300zx alarm install -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
lrciii
Member - Posts: 15
Posted: June 16, 2002 at 1:49 PM / IP Logged
Thanks Big Dog!
Just the info I needed, should make this project much easier!
Thanks!
Lee
www.raising-cain.com
caraudioshopbm
Member - Posts: 25
Posted: June 18, 2002 at 1:57 PM / IP Logged
WELL LEE THE STARTER KILL IS THE VERY LEAST OF YOUR TROUBLES  HAVE YOU EVER TRIED TO ADD A  ACT TO YOUR CAR ?? GOOD LUCK & MAY THE FORCE BE WITH YOU lol
caraudioshopbm
Member - Posts: 25
Posted: June 18, 2002 at 1:59 PM / IP Logged
O YA FOOD FOR THOUGHT THA FACTORY ALARM IS VERY EASYLEY BYPASSED ALL SOME ONE HAS TO DO IS SCREWDRIVER IN LOCK & TURN HARD FACTORY ALARM DISARMED & NO STARTER KILL !!!!
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
