If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Monday, May 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
First thing you will notice is the two toggles. That website didn't have objects to represent an AC clutch or a temp switch.
For current load, the low side is ~6-10A the high side anywhere from ~20-30A. The relays I'm using are 30A rated as well as the fuses.
Secondary question if I may.. If anyone knows of a good resource (website, IOS app, etc) to help with circuit design and maybe to let you test the flow please let me know because that'd be awesome!
Thanks!
