Custom Fuse Panel w/LED's?
Scottiee25
Posted: July 28, 2003 at 8:07 PM / IP Logged
I am needing some help with a project I am working on. I am building a fuse panel in my center console for all of my accessories that I am adding to my car. What I am needing help with is installing the LED's in there as well. I am wanting them to turn on when the accessories are turned on so I know the fuse is good. The LED's that I have look like LED's for car alarms. The positive wire has a red wire and the negative wire has a blue wire. Can anyone please tell me how to install these so they will work with what I need them to. I know I need to put a resistor on them but what i need to know is do I hook the red wire up to my power wire for the accessories and the blue wire to a ground or how will I do this. Any help would greatly be appreciated. If anyone wants to look at what I am doing check my website and see. http://www.cardomain.com/id/kitt350
xetmes
Silver - Posts: 586
Posted: July 29, 2003 at 11:25 AM / IP Logged
Just hook the LEDs up to the side of the fuse that has no power when the fuse is removed.
auex
Platinum - Posts: 5,041
Posted: July 29, 2003 at 4:44 PM / IP Logged
Need to know if they are twelve volt led or two volt led?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
