Locating wires
domiyork809
Member - Posts: 29
Posted: January 17, 2004 at 9:20 PM / IP Logged
  Hi,
 What is the best way in general,  to locate alarm wires in any car ( locks, unlock, triggers and parking lights)?. Do they have an standard size?
 Thanks for all your help.
auex
Platinum - Posts: 5,041
Posted: January 17, 2004 at 10:09 PM / IP Logged
Well, the easiest way to find alarm wires is to get a diagram for the vehicle, that way you will know what color the wire you are looking for will be. Then you need to test the wire to verify that it is what you are looking for because there can be multiple wires of the same color in the vehicle.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mikeshonda750
Copper - Posts: 105
Posted: January 18, 2004 at 2:59 PM / IP Logged
I agree with the above post, grab a diagram and look. Most diagrams will give you good refrence points for a general location of where it is on the vehicle.
In general though
Domelights: Kick Panel
Door Locks: Kick Panel
Ignition Wires: Along the steering colum
Parking Lights: Headlight switch
Tach Refrence: Ignition Coil under hood, Fuel injector, ECM under hood
Brake Lights: Switch above brake pedal
I will however say this, on alot of stuff today, espicially Dodge vehicles, it doesent matter if your find the correct wire or not, you have to match resistance on that wire for it to become useful.
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
