installing factory switches
nantan
Posted: March 27, 2004 at 9:33 PM / IP Logged
hi, i have an 03 s-10 that came with manual doors, windows and mirrors. i have recently bought and installed oem power mirrors, window motors, door locks, switches and door panels. the only thing that i dont have is the harness that goes across the dash. i need to know how to wire all of these items using an auxillary fuse block and relays. a diagram with color codes would be perfect.
the drivers switch has
 driver and passenger up, down
driver and pass lock, unlock
driver and pass mirror adjustment (heated)
the passenger switch has regular up, dwn, lock, unlock
all together there are about one million wires, thanks in advance for the help
nantan
Posted: March 29, 2004 at 4:42 PM / IP Logged
come on guys, please help
sparkie
Platinum - Posts: 2,061
Posted: March 29, 2004 at 8:44 PM / IP Logged
Go to your local GM dealer and see if they will print out schematics for the required components.
They may charge you a small fee, but it will be worth it. If you got the parts from a A/C Delco dealer they may be able to help.
sparky
