What exactly is a Ground Loop?
phamine
Copper - Posts: 88
Posted: December 01, 2004 at 1:35 PM / IP Logged
How would someone make the mistake of doing this and why is it detrimental?
I am regrounding my engine. Would this diagram of my engine bay create a ground loop?
The circled areas are the grounding points. The red lines are my routing of the ground wires.
What exactly is a Ground Loop? -- posted image.
dxav
Silver - Posts: 314
Posted: December 01, 2004 at 3:07 PM / IP Logged
I would suggest grounding each component separately. Absolutely minimally, remove the cable between the left shock tower, and the intake manifold, but you will still have imposed ground loops.
A ground loop occurs when there is more than one ground connection path between any two components. Having more than one path to ground forms the equivalent of a antenna which picks up interference.
DXAV
phamine
Copper - Posts: 88
Posted: December 01, 2004 at 7:02 PM / IP Logged
Would this be better? The ground wire are one to one now.
dxav
Silver - Posts: 314
Posted: December 02, 2004 at 8:01 AM / IP Logged
It is better, yes, but not the best. You should be fine with this design.
Did my description make sense?
Good Luck,
DXAV
phamine
Copper - Posts: 88
Posted: December 02, 2004 at 9:58 AM / IP Logged
Yes it does. Thank you.
realitycheck
Silver - Posts: 751
Posted: December 02, 2004 at 10:22 AM / IP Logged
Hey man heres you a link to one done on a 7thgen civic and what he noticed about the benefits of it. http://www.7thgencivic.com/forums/showthread.php?t=155307
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
