the smoked speaker
bassrider20hz
Member - Posts: 40
Posted: December 21, 2004 at 7:49 PM / IP Logged
hey every one wutsup today i was playing aroung with a home amplifier trying to replace a fuse that was burned from a long time ago. it turns out that there is something really bad with amp. i hooked up a car speaker it was a 6 by 9. ok so this is what happened.
i hooked up the speaker and turned on the amp and after anout 3 seconds the speaker started smoking. the was a lot of smoke coming from the voice coil of the woofer. WTF i quickly unpluged it i thought the speaker was dead. the i left it alone for about an hour and i wanted to see what happened to the speaker and i pluged it in my car. wow, it works i dont see any problems.
what do you think happened. why does the speaker still work.???
auex
Platinum - Posts: 5,041
Posted: December 21, 2004 at 7:59 PM / IP Logged
You probably just started to melt the plastic coating in the voice coil.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jeffchilcott
Platinum - Posts: 2,483
Posted: December 23, 2004 at 1:00 AM / IP Logged
never heard that before.    I guess if it works it works       the question is for how long?
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
