Venture Remote start
yyqbear
Posted: January 12, 2005 at 12:50 AM / IP Logged
I have a 99 Chevy Venture. I have a CT-3300 hooked up. I can get it running only with the emerg. brake pedal activating no head lights or in the daytime. It seems to loose the Tach after dark or when the headlights are on.
ck auto
Copper - Posts: 257
Posted: January 23, 2005 at 10:51 PM / IP Logged
hi what wire did you use for tach what did you use for bypass module
good luck
kirk
yyqbear
Posted: January 24, 2005 at 7:17 AM / IP Logged
I used the white wire from the split cover on the engine. I used the CT300 bypass system.
I got it running. I just hooked up the ground wire (active when remote is started)  to the emerg. brake wire. Works well.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
