2004 gmx envoy xuv wiring question
crna1
Posted: January 18, 2005 at 7:39 PM / IP Logged
can any of the obviously intelligent people here help me out..i have a 2004 gmc envoy xuv, just bought an after market tire pressure monitor. i need to power the receiving unit with a 12v line and an accessory (switched) line
in the old days i would just reach under the dash and help myself to a wire.  However, the dealer in town here says the electronics in this vehicle are so inter related that i can not do this
any one here clue me into a safe couple wires to splice into
thanks
scot
the don
Member - Posts: 22
Posted: January 18, 2005 at 8:22 PM / IP Logged
tap the rear wiper fuse located on the left  side dash this sould be ing then tap the cigert plug that will your consant and groud thats pretty much all ive done this with dvd players in envoys and yukons
ladys if i can,t fry it i don,t eat it
the don
Member - Posts: 22
tap the rear wiper fuse located on the left  side dash this sould be ing then tap the cigert plug that will your consant and ground thats pretty much all ive done this with dvd players in envoys and yukons
forbidden
Platinum - Posts: 5,354
Posted: January 18, 2005 at 8:26 PM / IP Logged
Scot, most Gm's use the same color wiring for the main power harness. Take off the lower dash bezel under the steering wheel and expose the main power harness from the ignition cylinder. Pink wire should be +12v ignition and +12v constant should be red. Chances are they are a larger wire as compared to the rest. Make sure that the lines you hook up to these circuits have fuses on them.
the don
Member - Posts: 22
Posted: January 18, 2005 at 8:28 PM / IP Logged
tap the rear wiper fuse located on the left of the dash that sould be ing then find the cigret pulg tapin there that will be yor costant it will hold the load then gruond thats it  ive done this with dvd players on yukons and envoys no probelm
crna1
Posted: January 19, 2005 at 11:42 AM / IP Logged
thanks for the replies, going to get out this weekend and take a crack at it..will let you know if it works
scot
scot
crna1
Posted: January 22, 2005 at 11:13 PM / IP Logged
heres how it went...could not find rear wiper fuse in dash. did not have the guts to mess with wiring in steering column. but...follow the wires, found a secondary fuse/relay distribution box under drivers seat..has a full time 12v line, many accesory fuses, and is convenient to my wiring.  so will use this
i appreciate the offers of help tho..thanks
scot
