tachometer install
majkowskid
Posted: February 15, 2005 at 10:21 AM / IP Logged
i have an 04 ford f150 heritage pickup with a 4.6 l v8 in it.  i am trying to install an aftermarket tach in it. there is NO tach from the factory.   i have purchased the ford racing distributor less ignition systems tach driver, which i was told will work.  it says to tap into the crankshaft position sensor wires, which ihave, and the box will give me the tach signal i need.
i have done this and it doesn't work.  i have tried tapping into a pin which i was told to on the pcm for tach signal, but that didn't work either.
anyone ever use one of these tach drivers before?  any suggestions?
Race1999
Posted: February 26, 2005 at 9:55 AM / IP Logged
I also know that you can tap into the fuel injection wires only if they are port style
secureauto
Copper - Posts: 197
Posted: March 03, 2005 at 1:27 AM / IP Logged
Look at the Tachometer info,
2004 Remote Start info
you can also try this site,
Rostra tach and VSS info
ASE Certified
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
