96 skylark remote starter Q
slednboard
Member - Posts: 7
Posted: November 12, 2002 at 6:47 PM / IP Logged
I've installed a commando EZ-2200 in a '96 Buick Skylark.  The module starts the car fine, but after it starts, it shuts off the engine.  It will start the engine, and then shut it off again.  It does this 3 times and then quits.  I haven't installed the Passlock bypass kit yet, but I leave the key in the ignition.  I don't think this is the problem, but I can't find anything else wrong.  Anyone have an answer?
Also, this is supposed to be a "tachless" system, but there is a dip switch to turn on the tach sense.  Can anyone tell me where to find the tach wire?
I'm new to this forum, and any help would be appreciated.
Player69
Silver - Posts: 504
Posted: November 12, 2002 at 6:56 PM / IP Logged
Passlock is your problem.  No question about it.
Do not use the tachless. Tach is white at the coil.
djfearny2
Silver - Posts: 810
Posted: November 12, 2002 at 6:57 PM / IP Logged
check your tach wire , make sure it is connected and you get a reading out of it,. one or set your time rate ont the remote start for the .06 first than if you need more increse it by one each time as according to the book .  and it should have a tach but   if the dip is set to tach sence than shut it off and try that cause this happens when the tach is not learned or is bad.  the wires are in a v6 is purple white at coil pack and in a 4 cylinder. it is white in a 16 pin connector located at top right side of motor.
Jon
Installer/Help Technician
---coral springs florida---
Player69
Silver - Posts: 504
Posted: November 12, 2002 at 9:21 PM / IP Logged
You can check your tach wire if you want but the problem is definately the passlock.  Putting the key in ignition will not work for passlock.  If you were to turn the key on, thats a different story ;)
slednboard
Member - Posts: 7
Posted: November 13, 2002 at 6:09 AM / IP Logged
Thanks for the info.  I didn't think the car would even start if it were the Passlock?
Player69
Silver - Posts: 504
Posted: November 13, 2002 at 8:00 AM / IP Logged
It will start and shut off right away.  Some will crank and not start.
slednboard
Member - Posts: 7
Posted: November 14, 2002 at 8:07 AM / IP Logged
I think I found the tach wire.  What should I see on the DMM?  Is this an analog signal?  ie: volts proportional to RPM?
Player69
Silver - Posts: 504
Posted: November 14, 2002 at 11:39 AM / IP Logged
Hook - lead to ground and set DMM to AC you should see between 1 and 6 volts and yes it will be somewhat proportional to RPM.
karbon14
Posted: November 14, 2002 at 6:06 PM / IP Logged
Man the problem is without a doubt the passlock system, why not listen when some one advises you of this
slednboard
Member - Posts: 7
Posted: November 14, 2002 at 7:02 PM / IP Logged
I wasn't doubting that the Passlock was the problem.  I am taking his earlier advice and hooking up the tach wire.
