2002 subaru wrx auto starter trouble
dm2222
Posted: December 03, 2002 at 4:01 PM / IP Logged
I have an auto starter in my WRX and I want to know how I can get it to work with the factory alarm.  The auto starter can trigger the door lock/ unlock, but it does not arm/ disarm the alarm.  As of last year, no one could answer this.  I am hoping someone has an answer by now.
securinu
Silver - Posts: 772
Posted: December 03, 2002 at 6:13 PM / IP Logged
pull the door panel if the key activates the alarm otherwise it might be internal to the factory module . in which case may not be possible all my info has is lock /unlock no arm disarm info.
NismaX
Copper - Posts: 104
Posted: December 03, 2002 at 8:15 PM / IP Logged
You cannot disarm the factory alarm system in these cars.  You might as well install an aftermarket system that has an alarm in it too.
Jon
TheShadowWRX
Posted: December 04, 2002 at 1:07 PM / IP Logged
You can do it, if you have the upgraded subaru alarm.
There are a few threads on it at www.nasioc.com
Mike
dm2222
Posted: December 04, 2002 at 5:42 PM / IP Logged
How do I know if I have the upgraded system?  If I have it, How do I wire in to it?
netZ
Member - Posts: 27
Posted: December 05, 2002 at 5:38 PM / IP Logged
if you have a siren attached to the passenger side strut tower, then you do have the subaru factory alarm upgrade...
if you need help with your setup, definitely go to: www.nasioc.com/forums someone should be able to assist you...
netZ
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
