switch and panel light wiring
tzed9
Posted: March 07, 2006 at 10:28 PM / IP Logged
Hi, new to the forum, looks like lots of very knowledgable peeps here, hope you can help please.
Got a power switch for a sub wired in the car, it controls the relay fine by providing ground for it.  This works no problem.  I bought some little 3v lamps with appropriate resistors.  I want a visual indication that the switch is on.  I can`t get the lamps to light when the switch is activated.
I realise that:
1. After using the resistor, the voltage is not enough to activate the relay.
2. The resistor and lamp cannot be in series with the grounding for the relay.
3. There probably has to be at least one diode in there somewhere to get this to work.
Can any kind person offer a wiring solution please?
Many thanks
More blue lights please!
mad550
Copper - Posts: 201
Posted: March 07, 2006 at 11:43 PM / IP Logged
Use the + positive output from the relay when on and ground the other side of the lamp
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
tzed9
Posted: March 08, 2006 at 1:45 AM / IP Logged
Nice, simple solution!
Respect, cheers Mad!
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
