custom taillights, 3157 bulb
jwagg
Member - Posts: 19
Posted: April 03, 2006 at 8:38 PM / IP Logged
Ive been making some custom taillights for my car for about a month, ive finally come down to wiring them, basically it deals with taking the turn signal function out of a dual filiment bulb. Usually, in this case, i would have used another 3157 size bulb in its place as the turn signal, but in this install im using a 194 bulb.
Im getting a fast flash, indicating that the bulb is burnt out, but it isnt. Im thinking its because the bulb isnt creating enough resistance in the circuit and its triping a sensor.
I measured the resistance across the 3157 bulb, its roughly 30 ohms. I measured the resistance across the 194 bulb, its roughly 6 ohms. Am I correct in thinking that if i buy a 24 ohm resistor, and place it across the 194 bulb wires, that it will create as much resistance as a 3157 bulb?
Will the bulb even light with the resistor on it? Any help would be great. Im not farmiliar with resistance, and im not sure if you can just add it up like that.
Big Dog
Gold - Posts: 1,265
Posted: April 03, 2006 at 8:45 PM / IP Logged
You answered all your own questions! Congrats! Now find ceramic resistors which can carry that much current.
Prepare your future. It wasn't the lack of stones that killed the stone age.
jwagg
Member - Posts: 19
Posted: April 03, 2006 at 9:09 PM / IP Logged
okay, so what kinda resistor do i need? a 24ohm 12 volt?
geepherder
Platinum - Posts: 3,668
Posted: April 03, 2006 at 9:30 PM / IP Logged
Use a heavy duty flasher- it should say it's not load sensing.  Using resistors would be counterproductive, because they'd eat up most of the wattage- your bulbs would only get a couple of volts or so (they'd be too dim).
jwagg
Member - Posts: 19
Posted: April 03, 2006 at 9:39 PM / IP Logged
what is a heavy duty flasher, where can i get one?
geepherder
Posted: April 04, 2006 at 6:02 AM / IP Logged
Its a flasher that won't change speed when a bulb goes out.  They're used on big trucks and you can get one at your local parts store.
jwagg
Member - Posts: 19
Posted: April 04, 2006 at 9:15 AM / IP Logged
is it a new socket? or is it a new bulb? I need to use s 194 bulb.
jwagg
Member - Posts: 19
Posted: April 04, 2006 at 10:19 AM / IP Logged
okay, i went to advanced auto parts, and they carry them, but they still indicate bulb outage by blinking twice the normal rate........... I have an 02 cavalier. Any sugguestions?
geepherder
Posted: April 04, 2006 at 6:42 PM / IP Logged
Then you got the wrong thing.
jwagg
Member - Posts: 19
Posted: April 04, 2006 at 10:22 PM / IP Logged
i didnt buy it. It says heavy duty flasher. I believe model number ep27. its a square one. I was ready to buy it, but on the package it says "heavy duty flasher" indicates bulb outage by flashing at twice the normal rate.
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
