05 grand am clock
c_sb
Posted: October 16, 2006 at 8:21 PM / IP Logged
While installing an Autostart in a 05 grand am, i noticed that the clock/tuner was nolong lit(base model tuner/CD). All the rest of the radio is lit as well as the rest of the dash. I am still able to tune the radio and all of the fuses are good. Any suggestions on what to look for.
Moderator - Posts: 12,488
Posted: October 16, 2006 at 8:33 PM / IP Logged
Where did you tap into for the lights ?
c_sb
Posted: October 16, 2006 at 8:51 PM / IP Logged
Brown park light(+) wire in passenger kick panel.
Platinum - Posts: 13,725
Posted: October 16, 2006 at 10:59 PM / IP Logged
        The display of your radio should come on at power up    it is not dependant on your illumination circuit.   Well at least the older units weren't   Don't know about the new DataBus units
sparkie
Platinum - Posts: 2,061
Posted: October 17, 2006 at 6:13 PM / IP Logged
If the radio's display doesn't work with the key, then it is a internal radio problem (bulbs). It is extremely common for Pontiacs to have this problem. It is nothing you did. The radio may not work when under remote start.
sparky
