Can not set above 60 mph
Msu1878
Posted: April 27, 2003 at 10:34 AM / IP Logged
I just installed  an Audiovox CCS-100 in a 2002 Nissan Frontier 4 cylinder (I used the magnetic pickup too).  It works great below 60 mph but will not engage above.  Any ideas or suggestions?
the12volt
Administrator - Posts: 3,959
Posted: April 27, 2003 at 11:01 AM / IP Logged
Sounds like the servo doesn't have a strong enough vacuum source. Check your vacuum source and if necessary add a vacuum canister.
Can not set above 60 mph -- posted image. the12volt • Support the12volt.com
Msu1878
Posted: April 27, 2003 at 7:43 PM / IP Logged
I reset the unit to 4000 ppm and it now works great.  It works great, even at 85 mph, I didn't try any higher speed.
