subwoofer enclosure, 95 chevy ext. cab
willieisking
Member - Posts: 6
Posted: February 15, 2009 at 2:47 PM / IP Logged
Does anyone know where I can find some kind of plan or template for building a top fire subwoofer enclosure for a 95 chevy extended cab truck?
ryan95x
Member - Posts: 24
Posted: February 15, 2009 at 8:01 PM / IP Logged
You will most likely need to fabricate something if you want it to be vehicle specific.  Do you have any pictures of the area you were thinking of?
-Dual XHD6425 - HD Radio w/USB & 3.5mm in
-Power Acoustik PS4-840
-Infinity Components
-10" Clarion SW1051 in FG molded box
willieisking
Member - Posts: 6
Posted: February 16, 2009 at 11:21 AM / IP Logged
Well i want it to fit under the back seat so not a lot of room. I can still post pics if you think they will help
ryan95x
Member - Posts: 24
Posted: February 17, 2009 at 3:40 AM / IP Logged
I would suggest doing some measurements to see what kind of subs you can fit, I have seen the storage under the rear seats and you should probably be able to fit one, mabye two shallow mount tens.  Have you used fiberglass yet?
willieisking
Member - Posts: 6
Posted: February 17, 2009 at 8:48 PM / IP Logged
I have never used fg. however i do know a couple guys who know how to and will walk me through it if i can't just build one out of wood and carpet it
ryan95x
Member - Posts: 24
Posted: February 19, 2009 at 12:15 PM / IP Logged
Pictures would help, but from what I remember you would have a pretty tough time using only wood for that box because of the compact space.   If you have access to somebody that could help you with fg then I would say give them a ring and learn...
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
