Painting Fiberglass...Newbie
tnrplaya
Copper - Posts: 58
Posted: August 26, 2003 at 12:03 AM / IP Logged
Hello,
I am a newbie and I was wondering if any one can detail the proces of painting fiberglass to get the shiny, show car look. Any info or website w/ pictures would be gratly appreciated. thank you in advance.
~Alvin
PG Limited Edition Octane Aplifier
PG Ti400.2
(2) JL12w6v2
Focal 165KF
JL TR-690TXi
Sony XAV-7W
Sony 10 Disc MP3 Changer
X-box
APC 350W inverter
Monster 1/0
Irragi 180A Alternator
pureRF
Silver - Posts: 619
Posted: August 26, 2003 at 7:52 PM / IP Logged
you will want to sand with about an 80 grit with the finished box. once it feels somewhat smooth. then with 180 grit bondo,sand,bondo,sand,then do it again. then go to about a 400-600 grit with a wetsand. works for me. make sure there are NO bumps or anything like that. remember bondo does wonders. with the paint i would suggest bringing it to a pro body shop, but you can use a oil based high gloss paint then a clear coat on top of that. i did just a high gloss oil based on a box and it looks good as hell so just do some samples and see what u want.
dream it, build it, fiberglass it
JamesRH
Copper - Posts: 102
Posted: August 26, 2003 at 8:14 PM / IP Logged
get it sprayed with a "gel coat" by a body shop after you ihave sanded it fairly smooth, then you can use pray paint and paint it yourself with light thin layers to aviod runs...i find its that to be the easiest and least time consuming way to do it...
radioactive
Member - Posts: 36
Posted: September 09, 2003 at 12:11 AM / IP Logged
make sure your mold is entirely free from any defects and inperfections. apply the primer surfacer (2 coats )to fill in all little scratches. you can wetsand this primer with 400 grit very lightly. now apply the primer sealer (2 coats) which actually holds the color of the paint for full brilliance meaning it wont sink through and lose its potential. you rarely sand the sealer. after dried and ready apply wax and grease remover to clean it. spray your basecoat 2-4 coats. sand any runs, sags, etc. now you can clear your enclosure 2-4. wetsand          1000-1500. use a buffer to bring back the shine from the sanding.
hope it helps. let me know how it turns out
"The important thing is not to stop questioning"
