stretching mat for glassing question
fugit
Copper - Posts: 169
Posted: May 31, 2004 at 5:40 PM / IP Logged
When stretching the mat or fleece how do you make it have as little overlaps as possible?  Do you just do the best you can and then fix the outside with bondo, or try to have as few creases as possible?
"I'm Rick James bi***, enjoy yo' self Ah Ah Ah"
Dave Chappelle as Rick James
audiomechanic
Silver - Posts: 388
Posted: May 31, 2004 at 8:39 PM / IP Logged
just do the best you can, work it until it is the best it will get....if there are bad wrinlkes, they can be cut out and filled after it is resined
big_ed
Member - Posts: 10
Posted: June 13, 2004 at 6:58 PM / IP Logged
I use some spray adhesive to secure the fleece to the MDF rings.  That way you are stretching in usully only one or two directions to reach the edge of the enclosure.  That seems to work well.
Kick his A$$ c-bass
drunkenbreaker
Member - Posts: 29
Posted: June 13, 2004 at 11:45 PM / IP Logged
number of people helps alot.  one person will have trouble on a big piece, but when me and my bro do it together we could do a really complex piece with no overlap.  fleece will just keep on stretching, you just need alot of people with a little bit of strength.
