S10 Amp cover
modena0
Copper - Posts: 85
Posted: March 26, 2005 at 9:02 PM / IP Logged
I decided i wanted to make a FG cover for my amplifier/Cap behind the seat in my S10, so i went to work with some 1/2 in MDF, 2 oz chop mat and 32 oz of resin. here is what i have so far-
S10 Amp cover -- posted image.
And here is what the spot looks like without a cover:
Finally, i would like to know if anyone can tell me how to remove scratches and scuffs from plexiglass. not deep marks, just surface scuffs. do you use ultra-fine grit wetsand paper? buffer with clearcoat compound?
Any feedback would be appreciated.
-J
auex
Platinum - Posts: 5,041
Posted: March 26, 2005 at 10:44 PM / IP Logged
First question for ya, Why fiberglass? Wood would have been so much simpler.
Second, buffing wheel with polishing compound and a torch will take out scuffs. Be very, very, very, very, very, very, very careful using the torch. Just heat it up, not melt it.
Oh yeah, you should redo your ground. That doesn't look to be the best place for it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
modena0
Copper - Posts: 85
Posted: March 27, 2005 at 12:07 AM / IP Logged
it is an MDF base, just with fiberglass over it to A) hold in the FG, and B) make it easier to shape and paint with auto finish.
As for the ground, seems fine cause that metal sheet is bolted direct to the chassis.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 27, 2005 at 1:16 AM / IP Logged
Not to knock you at all but you could have made that with wood and just paint on some resin. You didn't need the mat at all.
auex - very observant, I never would have noticed that ground.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
modena0
Copper - Posts: 85
Posted: March 27, 2005 at 1:17 AM / IP Logged
err, meant to say "A) hold in the plexiglass"
modena0
Copper - Posts: 85
Posted: March 27, 2005 at 1:22 AM / IP Logged
and i needed a little practice with FG mat anyways... not to mention the wood was flimsy because it's not easy to make a sturdy box with a poorly made circular saw, a coping saw, and a sanding block.. i also wanted to raise the level to the height of the plexiglass over the MDF... it was worth it for the practice alone, i have a few projects either in progress or coming up, so the practice is useful.
modena0
Copper - Posts: 85
Posted: March 27, 2005 at 1:25 AM / IP Logged
auex
Posted: March 27, 2005 at 10:56 AM / IP Logged
That is cool, but just made it more difficult then it had to be.
stuntjester1
Member - Posts: 36
Posted: March 27, 2005 at 7:55 PM / IP Logged
looks good makes it look a lot more one off.
realitycheck
Silver - Posts: 751
Posted: March 28, 2005 at 8:24 AM / IP Logged
yeah man looks really nice looks like you got a good start on your glassing experience.  Welcome aboard the 12volt man.
