fiberglass drilling?
Will85iroc
Member - Posts: 41
Posted: April 08, 2005 at 5:42 PM / IP Logged
can fg be drilled or cut after its shaped and hardened????  (before painting...)  or should all holes and cutouts be done before???  thanks all...fiberglass drilling? -- posted image.
" will85iroc "
Rick_h
Copper - Posts: 50
Posted: April 08, 2005 at 6:19 PM / IP Logged
Drills cuts sands just fine after curing. Take your time though or it may crack if you force it.
Rick H...
Will85iroc
Member - Posts: 41
Posted: April 08, 2005 at 7:33 PM / IP Logged
is it that strong that i would have to use force? or is it like drilling screws thru wood? thanks...
" will85iroc "
Rick_h
Copper - Posts: 50
Posted: April 08, 2005 at 7:56 PM / IP Logged
Watch screwing in screws....
If you "wedge" screws in or over torgue them down I think it will crack.
You gotta pre drill the holes to the proper size so the screw is not wedging the figerglass.
Rick H...
auex
Platinum - Posts: 5,041
Posted: April 08, 2005 at 10:08 PM / IP Logged
Well, you should predrill any holes for screws. As for cutting, if you are doing a FG box with fleece then I usually cut the speaker holes out after the first layer with a razor blade. You need to pay attention to the ring while glassing ensure that the resin went through the fleece well. I trim the excess at edges after the all the glass has been laid and before I start sanding.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
