Circular motorization, how can I do it?
Oznium
Member - Posts: 24
Posted: April 26, 2005 at 2:34 AM / IP Logged
I want to make a subwoofer box (around 40 lbs) spin. It doesn't have to be super fast or anything. Maybe one rotation in under a minute. My plan is to have 3 of these boxes spin seperately. The wiring is not the hard part for me, but I can't seem to figure out how to motorize it.
Linear actuator? Window motor? Really strong 12v motor with custom gearing?
bikeboard15
Member - Posts: 15
Posted: April 26, 2005 at 1:42 PM / IP Logged
a linear actuator or a window motor wouldn't have enough strength to spin it. If you were to use a 12V motor with a chain system, that would do it
Oznium
Member - Posts: 24
Posted: April 26, 2005 at 1:49 PM / IP Logged
So like a 12v motor from a cordless drill? Any ideas of what rpm and torque I should look for?
Oznium
Member - Posts: 24
Posted: April 26, 2005 at 2:25 PM / IP Logged
Would a flange bearing like this (1.5" I.D. is the largest I can find) work for connecting the box to the motor plate?
Circular motorization, how can I do it? -- posted image.
Lincolnman
Member - Posts: 20
Posted: April 26, 2005 at 8:57 PM / IP Logged
You might be able to use a serpentine system, like the one that turns all of your accessories on your car's engine. If done correctly you can use one motor (possible from an electric fan or something). You could find the pulleys at a junkyard, buy your belts from the parts store and get the three speakers to spin in different directions and timing (if that's what you're looking to do). Never tried, but it sounds good in theory.
Nothing is impossible!
M&mfabrications
Copper - Posts: 95
Posted: April 26, 2005 at 9:58 PM / IP Logged
How are you going to wire it so that it doesn't get twisted up as the box spins?
M&mfabrications
Copper - Posts: 95
auex
Platinum - Posts: 5,041
Posted: April 26, 2005 at 11:02 PM / IP Logged
I could have sworn that I brought up spinning ampracks, this ought to get good.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Oznium
Member - Posts: 24
Posted: April 27, 2005 at 2:19 AM / IP Logged
Wiring would be done with 2 metal rings on one side. The other side would have 2 spring loaded metal contacts (sliding van door contacts). I have not tested this, but I assume it will work. If for some reason, a solid connection is not made, I could always just use regular wire and program them to spin approximately 10 times in one direction and then turn around.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 27, 2005 at 2:44 AM / IP Logged
WHY.....just ...WHY, Jeeze. How does this have anything to do with good sound?  WHO are you trying to impress
My God Man, focus on something more important........so WHAT, if you can do this.....
WoW......
Page of 3
