dowels
lilbenny
Copper - Posts: 116
Posted: May 08, 2005 at 9:57 PM / IP Logged
ive been making my sub boxes for the longest tiem.. im finally at the point where i mount my sub rings... the only thinks is that i cant seem to hold them up.. i read somewhere to use dowels and a hot glue gun but their not strong enough... i was going to resin them but i still need to fing out the sq ft measurements so i cant do that.. any suggestions?
M&mfabrications
Copper - Posts: 95
Posted: May 08, 2005 at 10:11 PM / IP Logged
What size dowel are you using? I have always had good look with that method using 1/2 inch dowels. How are your rings oriented while you are trying this? If you have them facing upwards toward the sky then you should be able to get by with using the hot glue method.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
