Pre-wrapping w/ fleece before vinyl?
hayamakun
Posted: January 06, 2006 at 2:18 AM / IP Logged
I know wrapping a subwoofer enclosure with fleece before vinyl-wrapping would produce a smoother look.
Is this method better/more recommended than regular sanding?
If so, what adhesive would you use from the fleece/fabric to mdf/fiberglass. What adhesive from vinyl to fleece?
Sessland
Copper - Posts: 58
Posted: January 26, 2006 at 9:53 PM / IP Logged
Sounds like a way to try to get out of sanding.
Do it right the first time and you shouldn't have to cover up anything with fleece.
tcbturbosux
Copper - Posts: 69
Posted: January 27, 2006 at 12:27 PM / IP Logged
If you wrap it in fleece then somewhere along the way youll have to deal with the bunch-up.
Sand it.
Uncle Gumby
97blackrodeo
Member - Posts: 34
Posted: January 27, 2006 at 4:31 PM / IP Logged
1lb batting works well too. Headliner foam will work as well if the box doesnt have crazy curves.
