Fiberglassing dash
dan476
Member - Posts: 31
Posted: July 16, 2006 at 7:58 PM / IP Logged
hey guys, I got an old dash that is in pretty bad condition, got a lot of cracks and is a little bent because of cracks. could you tell me what would be the best way to fiberglass it? should i use some sort of foam to plug up the cracks and also when surface is uneven (one side looks like it has a dip in it) what should i do to even it out?
Fiberglassing dash -- posted image.
~Dan
dan476
Member - Posts: 31
Posted: July 16, 2006 at 8:15 PM / IP Logged
sorry computer double posted this one, please delete
~Dan
Melted Fabric
Silver - Posts: 509
Posted: July 17, 2006 at 12:21 PM / IP Logged
When you fiberglass it, how do you want it to look after you are done?
Will you be making a copy of your current dash and do it in fiberglass?
Are you making a fiberglass "cover" for your dash?
Or... Are you just trying to correct those cracks and keep your dash looking the same?
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
