Sharp corners for glassing?
dkeshish
Copper - Posts: 92
Posted: November 07, 2006 at 11:59 PM / IP Logged
Hi guys I am in the process of making a cover for where my amps are out of fiberglass, the hole for viewing the amps are in question here, when fiberglassing do I try to get the corners as sharp as possible? how would i do this? should i just get it down and then fix the edges of the square hole (for the amp to show) with bondo? thanks all
maglin
Copper - Posts: 206
Posted: November 08, 2006 at 12:05 AM / IP Logged
what angle?
i'm under the impression here that you use MDF to create corners and edges, rabit the MDF a bit to give the glass a pocket to sit in and bondo right over it.
