Posted: November 24, 2006 at 10:05 PM / IP Logged
Posted: November 24, 2006 at 10:22 PM / IP Logged
Posted: November 24, 2006 at 10:34 PM / IP Logged
Posted: November 25, 2006 at 3:38 PM / IP Logged
Posted: November 25, 2006 at 10:29 PM / IP Logged
Posted: November 26, 2006 at 12:00 AM / IP Logged
Posted: November 26, 2006 at 12:59 PM / IP Logged
Posted: November 26, 2006 at 2:33 PM / IP Logged
Posted: November 26, 2006 at 2:34 PM / IP Logged
Posted: November 26, 2006 at 2:35 PM / IP Logged
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I want to take up all the space in the rear. The subs are xtant 104sThe box i have now, built per xtant specs, sounds really good. Its tuned to around 28hz but I have slight port noise if you listen to the subs from the back of the car.I would like to do some slotted ports, that way i could put them on the bottom of the box where they wouldnt really be noticeable. I want the box to come close to the top of the rear seats.My plan is to build the boxes for the subs separate and then build the fiberglass around them. Sound is very important in this build, that is why I am choosing to do it that way. I also want to flush mount the amps facing the rear of the car.Im going to paint the box the color of the car.Im a painter so the body work isnt an issue.Thanks for the helps guys, maybe this will point you more in the right direction.
