subwoofer enclosure design?
tbradley_2
Member - Posts: 8
Posted: October 10, 2007 at 11:29 PM / IP Logged
Hi all,
I am new to this forum and am looking to gain some knowlege and advise.  I did use the search tool for this post, but this is my design so I am wondering if it will work.
I will be doing a custom trunk install in 1992 240sx S13 Hatchback.  I have two Alpine Type R's Subwoofers @ 4ohms  http://www.alpine-usa.com/US-en/products/product.php?model=SWR-1242D
Currently i do not have the amps two push them, but i will be getting good amps to push them to there peak.  I was possibly thinking of getting two of the Alpine PDX 1.1000   http://www.alpine-usa.com/US-en/products/product.php?model=PDX-1.1000
But cost is an issue and these are expensive...but i am going to get something that puts them to there peak.
So,  I was thinking about making a custom box to fit in the hatch of the 92 240sx.  and have everything mounted down includes the amps on a separate peice.  Then on top of that have a large peice of custom molded fiberglass design that can easily be removed, revealing the custom box and amps mounted to the floor.
I have attached some pictures to explain myself a little better.
The dimensions of the box are in the picture.
The first picture is just a basic layout.  It is a top view and does not have any angles involved in it.
The Second is my box design.
The amp portion will be a separate piece under the fiberglass overlay.
subwoofer enclosure design? -- posted image.
Now:     1. should I have a piece of wood dividing the subwoofers within the box?   2. I have two port wholes per sub, for a total of 4 @ 4inches in diameter each.  Will that work? suggestions?   3.  Is the size of my box okay? the volume of the box?  The dimensions just show to the exterior..so assume 3/4 inch mdf board?  4. Should the subs be in the shown position..or can i invert them? etc.
That is the box design. So that is my first thing.  My second is my amps mounted to a board that will be flush with the box.  Then I will have the piece of custom molded fiberglass sit onto of everything and fit flush.  But that is my last priority.  For right now i am just concerned about the box design.  Size? volume? port holes? etc.
Thanks very much in advance,
I hope that I am sounding clear, if not just ask and i will try to clarify.]
Tyler B.
Tyler B.
tbradley_2
Member - Posts: 8
Posted: October 10, 2007 at 11:47 PM / IP Logged
Here are two more mods to the box.
The first featuring a divider in the middle of the box, separating the two.
The Second featuring the separted piece in the middle...and a piece going down ...forcing the air to the bottom of the box...and then up through the port holes.
Which is the best idea? or what will work the best?
Tyler B.
Thursday, January 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
