parrot 3100 in 05 suburban
autocomjoe
Member - Posts: 11
Posted: December 28, 2006 at 8:45 AM / IP Logged
I am installing a parrot 3100 in an 05 suburban with a factory bose system. I have used the cell-site harness in the past and didn't get the sound quality that I did in vehicles that I spliced directly into the speaker wires. Is it a big deal to spice in after the amp? If not, are the wire colors the same as they are at the back of the stereo?
integratyper934
Copper - Posts: 150
Posted: December 31, 2006 at 1:14 AM / IP Logged
the wires on the back of the stereo are the inputs to the bose. grap the spkrs after the amps and hook up the to front doors, and the rear doors(optional i hook up 2 spkrs on cars sometimes). then use the mute wire and a relay to cut the main 12volt to the bose amp to mute everything else.
Customautomotiv
Copper - Posts: 128
Posted: January 04, 2007 at 1:22 PM / IP Logged
Did you use the LOC-1 when installing the GMCSS-1? This converter tones down the pink noise and the poping sound that usually arises when using this harness.
elicoleman
Copper - Posts: 72
Posted: January 09, 2007 at 11:48 AM / IP Logged
What is the ohm rating on Bose system speakers?
2003 GMC Yukon, Kenwood 815DVD w/ Nav. Memphis speakers. Kenwood 1200W Amp, Alpine 400W amp. Rear view camera, headrest monitors. Parrot CK3100
You can vote in polls in this forum
