LED help
viper04649
Member - Posts: 17
Posted: July 17, 2004 at 12:10 AM / IP Logged
i am planning on making a grill  for my sub out of florescent acrylic and using leds to light it up.
will a uv led light up the acrylic better?
i know i want to run a wire from the ignition to a switch to a relay, from the relay, i will wire the leds (i am thinking 4 at the moment).  i think that is what i need to do, don't know how to do this.
  • where to get relay, and switch?
  • what gage wires?
  • should i fuse, if so how many amps?
  • are resistor or anything else used.
also, on the box, i want to be able to plug unplug the grill(i mean the leds from the power)
-travis
viper04649
Member - Posts: 17
Posted: July 17, 2004 at 12:11 AM / IP Logged
also, is there anything that i should read that might help with any of this?
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
