Relay HID wiring
lukeinva
Posted: October 14, 2006 at 2:06 PM / IP Logged
This may be dumb but I am just trying to double check things. I am hooking up relays to my HID so they will work correctly. I know that 86 is 12volt, 85 neg, 30 HID turn on 87 is suppose to go to the battery with a 20 fuse. Well this is my question which 87 goes to the battery. I have bosch 12v relays 20/30a which are good relays but they have 87 and 87a so do I just hook up one to the battery and leave the other unconnected or do I hook both up to the battery one positive one neg???  Any help would be appreciated thanks in advance!
KarTuneMan
Platinum - Posts: 7,056
Posted: October 14, 2006 at 3:26 PM / IP Logged
You will not use 87a. 86, or 85 will be the "trigger" to turn the lights on. I would wire a switch to throw a ground to 85. 12v to 86.
lukeinva
Posted: October 15, 2006 at 7:36 PM / IP Logged
Thanks I appreciate it!
