hids, 06 chrysler pt cruiser
bigboi06
Posted: April 15, 2007 at 11:56 AM / IP Logged
hey guys i just bought this hids for my 2006 pt cruiser and i need a realy dont know how to make one can any one tell me how to. the problem is one the car is off and i turn the hids on they light up but when i start the car they shut off dont know what it is was told i need a relay can any one help me please.
swerve
Copper - Posts: 149
Posted: April 15, 2007 at 12:13 PM / IP Logged
first off, what brand of hid's did you buy? does the kit use a harness that plugs into your factory wiring?
git yer swerve on!
antifork
Member - Posts: 43
Posted: April 19, 2007 at 7:30 PM / IP Logged
I had a similiar problem before on my ranger. my lights didn't turn off they just dimmed when the car was on and everything running on it(air compressor, system, etc). the best thing you can do is check if you have alot of things running to the battery and how much amps does it draw away. because with that info you can either A) get an upgraded alternator because everything else is sucking the juice or B) run a second battery. from there you can run the HIDs to a relay by using a 30 amp fuse for the lead wire and using the light wire as a turn on switch for the relay. thats how i got mine to stop dimming or shut off.
bigboi06
Posted: April 20, 2007 at 1:30 PM / IP Logged
the kit that i bought is the best dubs hid xenon conversion 9006 hb-4
and yes it has a harness that plugs into factory harness the hid are plug and play
bigboi06
Posted: April 20, 2007 at 1:41 PM / IP Logged
also if any one can give me step by step or a index  how to set the hids to the relay that would be helpful thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: April 24, 2007 at 11:23 PM / IP Logged
Don't do the "plug and play" thing. Get 12volts from the batter for your relays (one for each headlight) and use the neg trigger from the factory bulb harness to trugger the relay. The wire that goes to ground wehen you turn on your headlights, Wire it as a standard negative trigger,
hids, 06 chrysler pt cruiser -- posted image.The 12 volt out from the relay goes to the (POS)+ for the ballast. Ground the ballasts well....
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
