96 protege, led strips to switch
lanceam24
Member - Posts: 29
Posted: November 03, 2007 at 2:17 PM / IP Logged
i am installing two led stips where ur feet go in my 96 protege to a toggle switch. everything was working jus fine, then i disconnected the switch from the wires to cut them down and make em a little bit shorter and to cut the hole where the switch will go. i have the power wire going to my horn fuse i nthe fuse box. the problem is, whenever i plug the fuse bac into the fusebox it makes a little spark and burns off the wire touching it. and it also looks like it burns some of the plastic part of the fuse. it might b because i didnt disconnect all of the wires from the switch when i plugged the fuse back in...
Platinum - Posts: 13,723
Posted: November 03, 2007 at 7:00 PM / IP Logged
You have somehow grounded the power wire or you have a bad LED unit.
lanceam24
Member - Posts: 29
Posted: November 03, 2007 at 8:48 PM / IP Logged
yea ok, when i disconnected, and reconnected all the wires, i put the power wire in the wronge place, thanx
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
