subwoofer that does not work
lamigra05
Member - Posts: 39
Posted: December 30, 2007 at 10:36 PM / IP Logged
Guys, and girls. It's interesting because i am confused. See i have everything hooked up and my amp turns on but its not pushing anything to the subs. Any possible reasons why it does not work will be appreciated and i know there are a lot of reasons.
signing off: Nanoo Nanooo
wat it do?
KPierson
Platinum - Posts: 3,527
Posted: December 30, 2007 at 11:20 PM / IP Logged
The most likely causes:
1. No signal from head unit
2. Subs not hooked up or not hooked up correctly
3. bad head unit (no output)
4. bad amp (no output)
5. bad subs (blown)
If you have another known-good source unit you can try plugging it in to the amp to rule out it is a signal in problem.
If you have an ohm meter you can disconnect the subs and measure their resistance to make sure they are connected properly.  Past that, it will be best to swap components out until you find out which one is causing the problem.
Kevin Pierson
lamigra05
Member - Posts: 39
Posted: December 30, 2007 at 11:27 PM / IP Logged
Gracias man. i needed to hear this
wat it do?
tedmond
Gold - Posts: 4,610
Posted: December 30, 2007 at 11:30 PM / IP Logged
are the rca connections wired up? do you have it connected to the proper channel on the amp?
lamigra05
Member - Posts: 39
Posted: December 30, 2007 at 11:45 PM / IP Logged
Well, i am not sure because i am a total loser when it comes to this stuff, but me and my friend have tried a couple amps so far and the same thing keeps happening. Amp turns on but will not play the bass. We bought new RCA cables, a new Stereo deck, new sub woofer and even a new box.
wat it do?
KPierson
Posted: December 30, 2007 at 11:49 PM / IP Logged
I would check to see how the subs are connected to the amp as well.  How many subs are there (just 1 it sounds like).  How many channels does the amp have?
Kevin Pierson
lamigra05
Member - Posts: 39
Posted: December 30, 2007 at 11:54 PM / IP Logged
It's a 2 channel amp. I only have one sub. I think its the amps i am using. i got them for free at the goodwill. ha ha. But They turn on though. That is the thing
wat it do?
KPierson
Posted: December 31, 2007 at 12:00 AM / IP Logged
How big is the amp?????  Got a model number?
Kevin Pierson
lamigra05
Member - Posts: 39
Posted: December 31, 2007 at 12:17 AM / IP Logged
Nah, sorry man. i left it at my friends house. But i can tell you that it's a very old kicker amp, 2 channel and its pretty big but only pushes like 300 watts. lol
wat it do?
