two amps to a single voice coil sub?
theetimurban
Copper - Posts: 126
Posted: January 06, 2008 at 4:53 PM / IP Logged
Is it possible to wire two different amps to a single voice coil? Same wattage, but different amps.
Platinum - Posts: 13,726
Posted: January 06, 2008 at 6:14 PM / IP Logged
Yes and no.  They do make amps that are strappable, meaning you can connect 2 of them to the same voice coil.  They have to be the same identical amplifiers.  There are several manufacturers that use the same exact internal boards.  Thus being different amplifiers but the are really identical.  Planet Audio 2250 is the same amp as a Power Acoustic 3000D.
The amps have to be strappable.  What kind of an amps are you trying to do this with?
DYohn
Platinum - Posts: 10,741
Posted: January 06, 2008 at 6:59 PM / IP Logged
In general, no.
