sho jbl
midospike
Member - Posts: 9
Posted: March 04, 2003 at 4:14 AM / IP Logged
Hello,
        I am pulling the stock head unit out of my SHO with the prem JBL sound (amp sub etc..). I want to tap into the inputs of the JBL amp from the RCA"S of the head unit. I am guessing the output from the head(ford) is low volt like RCA's. I did it years ago but for got with wires i cut and tapped into. Any help would be great.
                                              marc
esmith69
Gold - Posts: 1,511
Posted: March 04, 2003 at 1:31 PM / IP Logged
Yes you are correct, the output from the head unit is low-level, however the output from the factory amp is obviously high-level.  What are you trying to accomplish doing this?  Are you putting in an aftermarket head unit and still retaining the use of the factory amps?  If so you should use an OEM integrator harness, but first lemme ask you...what year is the vehicle?
midospike
Member - Posts: 9
Posted: March 04, 2003 at 2:48 PM / IP Logged
The car is a 95 sho with the top of the line JBL. Yes for now i want to hook up the aftermarket rca's to the factory system. what do i need to do? thanks
esmith69
Gold - Posts: 1,511
Posted: March 04, 2003 at 9:24 PM / IP Logged
http://www.crutchfield.com/cgi-bin/S-QKaf4nosDbb/ProdView.asp?s=0&c=11&g=751&I=142CFDK5&o=p&a=1&cc=01
This one uses the aftermarket head unit's speaker outputs instead of the RCAs but it'll still sound the same.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
