how to get to a 1 ohm load
oldskool23
Posted: May 28, 2008 at 7:38 PM / IP Logged
how do i get to a 1 ohm load by using 4 12 inch 4 ohm dvc
the12volt
Administrator - Posts: 3,959
Posted: May 28, 2008 at 7:42 PM / IP Logged
You can't get a 1 ohm load using eight 4 ohm coils... https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=4&I=42
how to get to a 1 ohm load -- posted image. the12volt • Support the12volt.com
joch1314
Copper - Posts: 301
Posted: May 28, 2008 at 7:53 PM / IP Logged
can't!!  you can get it as low as .5 ohms, and 2 ohms....but you can't get it too 1 ohm!
...half of the truth can be worse than a lie. <----Roger Russell said that..
haemphyst
Platinum - Posts: 5,059
Posted: May 29, 2008 at 8:46 AM / IP Logged
Why do you WANT one ohm? Are you under the mistaken impression that doubling your power (which it doesn't) by halving your impedance REALLY gets you something? Well it DOES get you something: Heat, inefficiency, higher distortion, shorter amplifier life.
What it DOESN'T get you is a noticeable increase in output. That amounts to less than 3dB, which, as I tell everybody, in a daily driver, this will be an insignificant (as in inaudible) gain. Are you building an SPL competition car? (Notice how I stressed COMPETITION. I do mean TRUE competition.) If so, then you simply chose the wrong woofers, and you should have somebody that knows what they are doing build your system.
KarTuneMan
Platinum - Posts: 7,056
Posted: May 29, 2008 at 9:20 AM / IP Logged
The spiz has spoken...
my ohmmeter is too short, and has a rash on it!
DYohn
Platinum - Posts: 10,741
Posted: May 29, 2008 at 9:54 AM / IP Logged
Question: how do i get to a 1 ohm load?
Answer: purchase the correct speakers.
KPierson
Platinum - Posts: 3,527
Posted: May 29, 2008 at 10:06 AM / IP Logged
Build the box half the size you think you need it to be.  Mount all 4 subs, but only hook two of them up.
Kevin Pierson
forbidden
Platinum - Posts: 5,354
Posted: May 29, 2008 at 4:05 PM / IP Logged
Use only one voicecoil on each speaker and wire them in parallel. Be aware that your overall power handling will be 50% of what it should be as one entire set of coils are not being used.
haemphyst
Posted: May 29, 2008 at 4:55 PM / IP Logged
That is a perfectly viable option, but total power handling will be about 80% of the total rated RMS, not 50%...
stevdart
Platinum - Posts: 5,816
Posted: May 29, 2008 at 5:19 PM / IP Logged
The total available RMS from the amplifier at 1 ohm is not likely to be twice what it is at 2 ohms.
Unless it's a super amp, it's a wash...and the amp is running hot at 1 ohms to get there.  And if it IS a super amp, OP would be using the correct subs to achieve the target impedance, right?  There are options, and then there are practical options.  This one falls into the first category,  which suggests why using one coil on each sub was not previously advised.
Thursday, May 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
