capacitor displays 12.8 volts, but displa
dabopper25
Posted: July 21, 2008 at 10:31 PM / IP Logged
I have a 5 Farad capacitor from Soundstream. It has a built in distribution block and voltage & current display. I am not getting any power to my car pc and 2 amplifiers. It displays on the capacitor 12.8 volts and 0 AMP current. What does this mean? Can the capacitor be blown and what may be the cause? Any info will be appreciated. Thanks.
Platinum - Posts: 13,725
Posted: July 21, 2008 at 10:38 PM / IP Logged
Is there a fuse between the amp and the capacitor? If so you need to check it with a meter or change it.
dabopper25
Posted: July 21, 2008 at 10:40 PM / IP Logged
Thanks for the reply.  There is no fuse between the capacitor and the ampilifers.  There is a fuse between the battery and the capacitor which is still good.
dabopper25
Posted: July 21, 2008 at 10:42 PM / IP Logged
If this helps any, the capactor has a funny burnt smell.  I am think its a blown capacitor causing an incomplete circuit which explains why the capacitor displays 12.8 voltage but displays 0 AMP current.  Why could cause a capacitor to blow is what I am wondering.
haemphyst
Platinum - Posts: 5,059
Posted: July 22, 2008 at 12:30 AM / IP Logged
Voltage surges, current surges, overtemp... Those are the things I know of that can cause one to blow.
audiocableguy
Copper - Posts: 630
Posted: July 22, 2008 at 2:29 PM / IP Logged
Caps are an interesting subject around here. You might want to take a look at the topic "capacitor" and see if your cap is worth replacing.
mobile1
Silver - Posts: 479
Posted: July 22, 2008 at 4:22 PM / IP Logged
I vote no.
DYohn
Platinum - Posts: 10,741
Posted: July 22, 2008 at 5:25 PM / IP Logged
dabopper25 wrote:
If this helps any, the capactor has a funny burnt smell..
capacitor displays 12.8 volts, but displa -- posted image. That's usually a clue.
