remote wire for second amp?
bullseye753
Copper - Posts: 61
Posted: July 27, 2008 at 6:17 PM / IP Logged
Im going to be installing my second amp.. i am going to use a distro. block for the power.. but for the remote can i just bridge it from amp to amp? is this a perfectly safe thing to do?
audioinstaller3
Copper - Posts: 59
Posted: July 27, 2008 at 7:15 PM / IP Logged
Yes its fine just to run the remote wire from one amp to the other
audiocableguy
Copper - Posts: 630
Posted: July 27, 2008 at 8:59 PM / IP Logged
I use a 30A Bosch Relay on the Remote wire at the deck. A 3 amp fuse to a relay to processors, amps etc. Adding more gear later, no problem. If a short does occur the deck won't be damaged. It's worth the $6 for the relay and 10 minutes of time.
s_goodie
Member - Posts: 44
Posted: July 29, 2008 at 11:24 PM / IP Logged
yes no problem other than loks unless you hie it good but it will work the same
Stuey BABE
