97 ram factory amp remote wire
frydchkn
Copper - Posts: 60
Posted: August 03, 2008 at 12:16 PM / IP Logged
I just installed an aftermarket radio on this 97 Dodge Ram with Infinity system, but I don't get any bass.   I'm assuming the door speakers have a factory amp attached to them and I am over looking the factory amp remote wire.
If this is the case, would it be wise to use a line out converter?
And, what color is the factory amp remote wire?
Any help would be greatly appreciated, Thanks ahead.
FRYDCHKN
Platinum - Posts: 13,725
Posted: August 03, 2008 at 7:20 PM / IP Logged
Did you purchase a wiring harness for the vehicle?  If so the amp turn on wire will probably be blue in color and it will be labeled power antenna.  If your new radio has a blue and a blue/white wire, connect the blue/white of the radio to the blue wire of the harness you purchased.
kickz l7
Member - Posts: 15
Posted: August 04, 2008 at 12:20 AM / IP Logged
http://www.dodgeforum.com/m_1295861/mpage_2/key_/tm.htm
read this and you may be able to figure it out. If not just do a search on the forum they have a lot of imformation.
frydchkn
Copper - Posts: 60
Posted: August 06, 2008 at 11:21 PM / IP Logged
Thanks I Am An Idiot...i am an idiot because I had overlooked the fact that this truck might have contained an external amp.  I remember looking for an automatic antenna, but its not automatic.  I should have followed the blue wire from the harness and noticed there was a connection on the other side.
All in all, I had gone back and attached it like u said 'i am an idiot', and it all worked like a champ.
Thanks to all,
FrydChkn
Note: this topic could be closed
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
