temperature vs subwoofers
frizkysquirrel
Member - Posts: 47
Posted: August 17, 2008 at 3:48 PM / IP Logged
i have an question about temperature.
is there any danger of damage involved with playing subwoofers during the very low temperatures of winter?
i live in michigan and during the winter it can go between slightly below 0 degrees Fahrenheit to just below 32 degrees Fahrenheit, during the middle of winter.
should i play my system at lower levels until it warms up? or will well built subwoofers not have a potential to be damaged by these temperatures?
thanks much.
haemphyst
Platinum - Posts: 5,059
Posted: August 17, 2008 at 7:27 PM / IP Logged
Most materials will "stiffen up" at those temperatures. The only part I would wory about (and very little, if at all) would be the adhesives holding the surround to the basket and cone.
If you are that worried about it, just wait a while 'till your cabin warms up a bit before you crank 'em.
whiterob
Copper - Posts: 351
Posted: August 20, 2008 at 12:35 AM / IP Logged
I live in Michigan and have never had a problem yet. You do hear (usually) a difference in sound from your sub(s) in the winter though but that is another topic.
frizkysquirrel
Member - Posts: 47
Posted: August 20, 2008 at 12:50 AM / IP Logged
yes i definitly noticed tht my subs just dont sound quite right in the winter. seems like less mellow. i really dont know how to explain it. but i was just curious if it was bad for subs.
