dynamatting
04nata
Copper - Posts: 358
Posted: September 17, 2008 at 11:00 AM / IP Logged
This stuff is really expensive and I cannot afford to do the whole car at once, question is, what is the best place to start and then move to next? to get the most effectiveness
also, Stevdart............that sheeting you used in your car from McMaster, I live in Arizona, do you think it will stand up to that kinda heat? I don't usually but the "ASPHALT" sented air fresheners.
Phreak480
Copper - Posts: 84
Posted: September 17, 2008 at 12:11 PM / IP Logged
there are products other than Dynamat. i am in the middle of doing my entire truck (quad cab pickup) with edead. i'm sure others cna chime in with additional alternatives
aznboi3644
Gold - Posts: 2,600
Posted: September 17, 2008 at 12:15 PM / IP Logged
you can try the eDead V1SE^2
04nata
Copper - Posts: 358
Posted: September 17, 2008 at 2:08 PM / IP Logged
04nata wrote:
also, Stevdart............that sheeting you used in your car from McMaster, I live in Arizona, do you think it will stand up to that kinda heat? I don't usually  buy the "ASPHALT" cented air fresheners.
edit
the12volt
Administrator - Posts: 3,959
Posted: September 17, 2008 at 2:11 PM / IP Logged
04nata wrote:
edit
...oO( scented )
dynamatting -- posted image. the12volt • Support the12volt.com
04nata
Copper - Posts: 358
Posted: September 17, 2008 at 2:13 PM / IP Logged
duh, I can't even spell SCENTED in 2 tries
frozenuts
Member - Posts: 36
Posted: September 17, 2008 at 4:23 PM / IP Logged
to actually answer your question, I would start with the doors, unless you are a trunk rattlin mofo from da wesside, then please do your trunk...for your neighbors sake.
Seriously, the doors are about the only thing that I have done in my last couple cars. I filled most everything else up with expanding foam insulation.
all bad things come in moderation. do not shop at fry's. Get your own log in Omar.
stevdart
Platinum - Posts: 5,816
Posted: September 17, 2008 at 9:56 PM / IP Logged
I still have the car that I installed that stuff in.  Haven't smelled asphalt for 4 years.  But I didn't skip (too many) steps when I installed it, either.  I helped the glue a little by using a quick spray of 3M 77 directly to the sheet metal, and made sure that I wiped the metal clean first.  I didn't go that extra mile by cleaning the metal with denatured alcohol, but that is a step that will ensure best adhesion.  For the rolling, I used a heavy steel seam roller that I used to use in paperhanging.  I don't think it's the heat of the day that will cause failure...I think it's the installation of the product.
04nata
Copper - Posts: 358
Posted: September 17, 2008 at 10:33 PM / IP Logged
cool, thanx, that will work good since I just got learnded on how to remove my door panels. Then on to the trunk, and no frozenuts, only the license plate, just a bit
reax222
Copper - Posts: 220
Posted: September 18, 2008 at 1:08 AM / IP Logged
I did peel and seal from home depot over my floor and pillars. I had a slight asphalt smell for a day or so. My alarm has shown just over 116 degrees in cab.
Thursday, February 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
