02 escape vehicle speed pulse signal
00sonoma
Member - Posts: 39
Posted: October 01, 2008 at 1:35 PM / IP Logged
installing an eclipse avn20d in an 02 escape v6 non hybrid
Need to connect the PURPLE / white wire from the head unit to a vehicle
Speed pulse wire can I use the tach wire from my remote start?
frozenuts
Member - Posts: 36
Posted: October 01, 2008 at 2:00 PM / IP Logged
If you are a Steelers fan, it should be a grey and black wire located at the cruise control servo on passenger fender. (that is what directechs says)
If you are an eagles fan, just wrap some wire around your muffler bearings. That will activate your exhaust systems bluetooth network and communicate the vehicle speed to the radio. (that is cuz the average eagles fan thinks that they need to change their muffler bearings every 5000 miles)
You don't want to hook it to the tach wire, because that does not show the vehicles speed, just the engines.
Good Luck!
all bad things come in moderation. do not shop at fry's. Get your own log in Omar.
00sonoma
Member - Posts: 39
Posted: October 01, 2008 at 3:34 PM / IP Logged
also there is no brackets or cage to hold
The unit in the dash where could I get one
There was only the 8 mm stews included
