Parking Brake Lead indash video
ryanneves
Posted: March 12, 2003 at 1:53 PM / IP Logged
Have a clarion VRX935VD and wanted to be verify if by grounding the (green-green <parking brake>) lead that DVD's would play without having the parking brake on.....or is there another way of bypassing the parking brake.
lagatbezan
Copper - Posts: 117
Posted: March 12, 2003 at 2:01 PM / IP Logged
if you want to bypass it, connect it to a ground. it will work.  i would connect it to a switch - connected to a ground, this way if you get pulled over, just flip the switch!
bberman1
Gold - Posts: 2,314
Posted: March 12, 2003 at 2:02 PM / IP Logged
You have it correct if you wire it to a ground you can bypass the parking brake.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
