subs not as loud as they should be
darkkon
Posted: November 08, 2008 at 9:59 AM / IP Logged
http://www.online/CarAu...roductid=17397
http://www.pioneerelectronics.com/PU...er/DEH-P3000IB
http://www.online/CarAu...roductid=12982
http://www.online/CarAu...roductid=19123
with a sealed box, subs wired at 2 ohms.
80 amp AGU fuse and the fuse on the amp is three 25 amps so no problem with the fuses there.
if i turn the headunits volume up to about 30 they start getting louder but thats way to high for the speakers and they distort. the speakers in the car are 4 ohm. and they are 4x6 with two tweeters in front.
93 nissan pathfinder, enclousure is sealed and in the trunk facing the back
i checked all the settings on the headunit and the amp, i turned all of them up all of the way and they still arent even hitting nearly as hard as i had them, they are very quiet and should not be this quiet as i have had installed them in a different car and have had them actually running where you could hear them, you can barely hear them and they are moving a little bit.
DYohn
Platinum - Posts: 10,741
Posted: November 08, 2008 at 10:30 AM / IP Logged
Sounds like you may have one sub out of phase with the other.  Check your wiring.
ckeeler
Gold - Posts: 1,461
Posted: November 08, 2008 at 10:41 AM / IP Logged
i thought the same thing too until i read where he said they are barely moving. do you still think it could be they are out of phase?
darkkon
Posted: November 08, 2008 at 10:52 AM / IP Logged
no, i took them straight from my old car and they worked perfectly then. the pos is on the pos and the neg is on the neg
ckeeler
Gold - Posts: 1,461
Posted: November 08, 2008 at 10:58 AM / IP Logged
he means the way they are wired together in the box. not how they are hooked to the amp
darkkon
Posted: November 08, 2008 at 11:03 AM / IP Logged
yes, in the box they are fine and to the amp they are fine.
DYohn
Posted: November 08, 2008 at 12:35 PM / IP Logged
Then either your speakers are blown or the amp is blown - or perhaps just set up incorrectly.  How is your LP filter set and did you set the gain correctly?
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
