line driver
upzaw2000
Member - Posts: 43
Posted: December 07, 2008 at 2:41 PM / IP Logged
quick question,
i am about to get a line driver... but my question is... if i have 2 sub amps.... and i split the RCA lines so the signal goes to both amps... does it also split the voltage over the 2 amps....
example: line driver 10 volts/2 amps= 5 volts per amp?
Platinum - Posts: 13,725
Posted: December 07, 2008 at 3:14 PM / IP Logged
10 volts divided by 2 amplifiers = 10 volts to each amplifier.     Why are you even thinking about a line amp?   The input impedance of an amplifier is around 10,000 ohms.  You can easily connect 10 or more amplifiers to even a basic deck without losing voltage from the deck..
upzaw2000
Member - Posts: 43
Posted: December 07, 2008 at 3:20 PM / IP Logged
Why would i want a line driver?
the deck only puts out 3 or 4 volts.... I compete in Usaci so the extra voltage coming through the RCAs will matter.
Posted: December 07, 2008 at 3:42 PM / IP Logged
Are you using amplifiers designed for use in automobiles?
haemphyst
Platinum - Posts: 5,059
Posted: December 07, 2008 at 5:03 PM / IP Logged
Wrong answer. If you have an amplifer that has an effective sensitivity that even TOUCHES the output voltage of the amplifer, (example: let's just say the amp has a range of 200mV to 8V, and your present deck offers 3V) you will get full output from the amplifier... You cannot NOT get full output. That's the fact. The reason that i am asked if you were using amplifiers for the car, then your 3 to 4 volt deck will be perfectly adequate to get all the power from your amps; they WILL be driven to full output.
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
