new radio, speakers not working, 05 sonata
mysonata05
Member - Posts: 10
Posted: January 05, 2009 at 12:03 PM / IP Logged
I need some help I just installed a aftermark radio in my  2005 Hyundai Sonata, the radio works but there is no sound. The car does not have a factory amp, I checked all the wiring connections twice and still no sound. what could be the problem do I need to install aftermark speakers aswell? any suggestions would be apreciated.
Platinum - Posts: 13,725
Posted: January 05, 2009 at 12:08 PM / IP Logged
You did purchase the harness, didn't you?  If so connect the blue wire of the harness to the blue/white wire of your new deck.
mysonata05
Member - Posts: 10
Posted: January 05, 2009 at 3:56 PM / IP Logged
Yes I purchased the harness, I will try the suggestion you offered, Thanks. But would happen to know where I could locate the factory amp, I will be installing my amp after awhile and I will need to take that one out or dis connect that one.
Posted: January 05, 2009 at 4:06 PM / IP Logged
new radio, speakers not working, 05 sonata -- posted image.BatteryORANGE(+)RADIO HARNESS
new radio, speakers not working, 05 sonata -- posted image.AccesoryYELLOW(+)RADIO HARNESS
new radio, speakers not working, 05 sonata -- posted image.GroundBLACK/ ORANGE(-)RADIO HARNESS
new radio, speakers not working, 05 sonata -- posted image.IlluminationBROWN / WHITE(+)RADIO HARNESS
new radio, speakers not working, 05 sonata -- posted image.Power AntennaGRAY(+)RADIO HARNESS
new radio, speakers not working, 05 sonata -- posted image.Amp Turn OnLT.GREEN(+)RADIO HARNESS
new radio, speakers not working, 05 sonata -- posted image.LF Speaker (+)TAN
new radio, speakers not working, 05 sonata -- posted image.LF Speaker (-)BLACK
new radio, speakers not working, 05 sonata -- posted image.RF Speaker (+)BLUE
new radio, speakers not working, 05 sonata -- posted image.RF Speaker (-)RED
new radio, speakers not working, 05 sonata -- posted image.LR Speaker (+)WHITE
new radio, speakers not working, 05 sonata -- posted image.LR Speaker (-)BROWN
new radio, speakers not working, 05 sonata -- posted image.RR Speaker (+)ORANGE
new radio, speakers not working, 05 sonata -- posted image.RR Speaker (-)GREEN
new radio, speakers not working, 05 sonata -- posted image.Amp LocationREAR PASS SIDE OF TRUNK
new radio, speakers not working, 05 sonata -- posted image.Steering CntrlsNO
new radio, speakers not working, 05 sonata -- posted image.Speed CntrlNO
new radio, speakers not working, 05 sonata -- posted image.Radio SecurityYES
mysonata05
Member - Posts: 10
Posted: January 06, 2009 at 10:53 AM / IP Logged
When I connected the white and blue wire that worked. Thanks!!!! I connected all three wires so that my antenna will work. Do you think this will be a problem later on?
Also I noticed a whining sound now comes from the speakers? is this coming from the speaker connection? or the ground connection? all I did was connect the two black wires together.
soundnsecurity
Gold - Posts: 2,720
Posted: January 06, 2009 at 11:13 AM / IP Logged
what kind of radio did you install?
mysonata05
Member - Posts: 10
Posted: January 06, 2009 at 12:12 PM / IP Logged
I installed a DUAL Xhd7714 200watts reciever
Posted: January 06, 2009 at 4:52 PM / IP Logged
There is a GOOD chance that the noise is coming from your radio.  You may have to live with it, or upgrade to another brand of Deck.    Does the deck not have a blue and a blue/white wire?   If it has only one, it should be fine connecting both wires from the car to the single wire from the deck.  If the deck does have both wires, Blue is power antenna, and blue/white is amp turn on.
mysonata05
Member - Posts: 10
Posted: January 08, 2009 at 1:16 PM / IP Logged
But the noise only starts when the car is cranked up, If I just turn the key there is no noise.
DYohn
Platinum - Posts: 10,741
Posted: January 08, 2009 at 1:25 PM / IP Logged
You can try grounding the HU separately (not using the factory ground connection) but Dual is a crappy build quality brand and you may not be able to eliminate it.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
