what amp do i need to get?
jyojiman
Member - Posts: 12
Posted: February 15, 2009 at 7:01 PM / IP Logged
I'm planning on getting two 12" 1600watt 4ohm chrome subwoofers. 800RMS and Spl: 90dB. I have tried to research on my own, but cannot decide on what kind of amp or how much power it needs to have.. please help!
forbidden
Platinum - Posts: 5,354
Posted: February 15, 2009 at 8:28 PM / IP Logged
And what brand name is attached to these subwoofers.... chrome is kind of scary.....
jyojiman
Member - Posts: 12
Posted: February 15, 2009 at 9:21 PM / IP Logged
the brand is Lanzar
spookiestylez
Silver - Posts: 531
Posted: February 16, 2009 at 1:09 AM / IP Logged
I wouldn't buy those subs. Instead I would go to a local car audio shop and see what they have to offer and what they recommend. There are TONS of better companies out there than Lanzar ( stands for flea market). At least if you go to a shop ( of a few for that matter) and hear a few different sets of subs, you will have a chance to hear what that extra dollar buys you. After you shop locally, and if you still need some help deciding, we can give you some ideas on some great sub ideas. But for the short answer to your question, a 600rms (or 1300w) amp of the same quality would suffice.
rtfm
jyojiman
Member - Posts: 12
Posted: February 16, 2009 at 10:55 AM / IP Logged
I actually got them as a gift from my friend.. so I'm just trying to make them work
jyojiman
Member - Posts: 12
Posted: February 17, 2009 at 8:36 AM / IP Logged
I got two 12' Pioneers - http://www...com/item_8710_Pioneer+Premier+TS-W1207D2.html and I got this amp powering them - http://www...com/item_8842_Power+Acoustik+OV2-1800.html according to what I've researched this should workout, but now i need to know how to hook them up.. I have a 2003 acura tl if it matters.
moparfan1234
Copper - Posts: 59
Posted: February 18, 2009 at 8:51 PM / IP Logged
whats the specs on them?
87 ramcharger eclipse CD5000 2 15" memphis M3 kenwood 900rms mono amps
99 dodge cummins diesel eclipse CD4000 1 12" memphis Mclass 800rms audiobuhn amp
nvisible1
Member - Posts: 31
Posted: April 21, 2009 at 11:03 PM / IP Logged
i would also like to now how many watts max amp i should get to power my new subs, i got 2 12'' power acoustik fubars, there 800 watts rms each, if im not mistaken shouldn't i get a 1600 watt amp?...holler at me idiot....
nvisible1
Member - Posts: 31
Posted: April 21, 2009 at 11:04 PM / IP Logged
forgot to mention, dual 4 ohm voice coils...
Platinum - Posts: 13,725
Posted: April 22, 2009 at 8:23 PM / IP Logged
If you believe the specs to be accurate, then yes you need an amp that will produce 1600 watts into a 4 ohm load or a 1 ohm load.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
