amp failure?
dannyszu
Posted: May 06, 2009 at 10:55 AM / IP Logged
Hey all, I have a 95 Integra with a 12" Bassworx (500w), and a 600w MTX Thunder, with a 1 farad cap and 4 gauge wire. Everything appears to be working, the light on the amp is as it should be, the cap reads 14 when car is turned on...I looked at all the wires, sub in and outs are as they should be, wires to the sub are in order...no fuses blown. What are some possible problems with this, I'm hoping my amp isn't messed, should I get a bench test as well?
DYohn
Moderator - Posts: 10,741
Posted: May 06, 2009 at 11:02 AM / IP Logged
You stated that everything is working... so what's the problem?
dannyszu
Posted: May 06, 2009 at 5:36 PM / IP Logged
Ahhh sorry, everything appears to be working but the sub is not moving...no sound, nothing.
joch1314
Copper - Posts: 301
Posted: May 06, 2009 at 7:00 PM / IP Logged
Have you metered the subs to make sure they're not toast?  What about the signal from the deck?
...half of the truth can be worse than a lie. <----Roger Russell said that..
pheonixgd
Member - Posts: 16
Posted: May 07, 2009 at 4:44 PM / IP Logged
Did you buy them brand new?...
Every time I have blown a sub, you can usually smell a nasty burning smell from the magnet/ voice coils; and as well, if you push the sub with your fingers it wont move back and forth properly it will feel jammed if its blown.
Another thing to check for is to make sure your ground is properly grounded, if it isn't it will cause your amp to cut out or not work at all even though the light may come on amp failure? -- posted image.
