toggle switch
xchrisx
Copper - Posts: 197
Posted: July 14, 2009 at 9:35 PM / IP Logged
How would I go about hooking my headlights, taillights and cluster gauge to a toggle switch and be able to alternate between my low beams and high beams when needed? also would I be able to use my brakes lights? how would I go about those working too? basically something happend with my wiring i cant figure out and itd be alot easier/cheaper to just run the stuff with a toggle switch and if need be relays.  if you could please maybe show a diagram of how id hook this up, thatd be awesome.  Thanks in advance!
bp
Platinum - Posts: 13,725
Posted: July 14, 2009 at 10:17 PM / IP Logged
It would probably be easier to fix your problem.   What exactly did you do to the car right before they went out?   What kind of vehicle are we dealing with?
xchrisx
Copper - Posts: 197
Posted: July 15, 2009 at 7:08 AM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp~TID~115069~get~last
follow that link and itll show everything that happened with the car.
bp
